Veritas 8 Installation
Guest Service2u
Guest Service2u
Thanks m8t
For all your Help
All the Best
Regards
mark
44834[/snapback]
Update..........
Called out to the Customer.
Panel front was already removed by customer.
Who ever put the System in used all 4 Core Wiring, No Tamper Circuits what so ever. PS. This is not the first Installation that has used only 4 Core Wiring
On inspection of the PCB (Which was different to the manual ??? )
Found lots of Dry Joints on the Screw Terminal on the PCB.
This is what was causing the Tamper Fault and Zone 8 to light.
Powered Down the Panel and Soldered all the Dry Joints.
Powered all back up and all fine now.
Got to say this is the First i have come across with Dry Joints.
All Working, Peasceful sleep for Neighbours now
Regards and many thanks for all your Help
Mark
45013[/snapback]
Are you sure it is not tampered therough DEOL? That will work with 4 core.
I am yet to come across a Veritas with dry joints on the panel. Still - there is a first time for everything.
45014[/snapback]
I have had 2.
45014[/snapback]
Ive seen one with wet joints when a pipe burst in a ceiling!
Ive also seen one with dry joints on top but thats another story - and Im not going back to that premessis ;)
