AJ600N Reset
Guest Charlotte Hartley
Some people really should look at the dates before replying. :rolleyes:;)
My AJ600N A1 alarm has failed and I was reading this correspondence with interest. The failure is that the transformer has burned out. I have read with interest that a failing battery will draw too much current which could explain why the transformer burnt out. I do not know what voltage the transformer gives out (yes I know I can count the windings but this is such a fag). Does anyone out there know what the secondary ac voltage should be? I tried a 10v rms transformer, but after a few seconds with all the lights on (when I guess the microprocessor is resetting itself), the alarm goes off with only the power light on and i cannot stop it. My guess is that 10v is too low. Can anyone help?
62301[/snapback]
18volts a.c.
but it really is a poor excuse for a panel...
Regards.
Guest Chris.Hudson
thankyou, I will try 18 volts. I will also need a new battery as it does not take any charge current. Maybe it is time to change it after all.
Yes change it. Post your location and someone here might be able to help.
Dave Oxendale
York based security systems engineer.
