Guest dewalty Posted March 19, 2005 Posted March 19, 2005 Hi Looking for some info from you lot. Hope this is not too stupid a question. Which panels allow for internal sounders to be programmed on or off, per programmed setting. Reason I ask is, I have a dog, and some times the dog is left in the house for an hour or so. And as im planning on getting a white noise sounder, i dont want it going off when the dog is in the house. I previously had an Ultimate ade panel, which I dont think allowed that. So any recomendations for a suitable panel or range would be great. I have a fair few id biscuits, so any that use these would be even better. Many thanks Jay
Guest Posted March 19, 2005 Posted March 19, 2005 if you have any zone that is not used you could bypass that zone and get the bypass status of that sone linked to programmable output that operates relay that cuts the power from the internal sounder... does it sound too unprofessional??
Guest Posted March 19, 2005 Posted March 19, 2005 if you have any zone that is not used you could bypass that zone and get the bypass status of that sone linked to programmable output that operates relay that cuts the power from the internal sounder... does it sound too unprofessional?? 44841[/snapback] also some sort of partial set linked to output might do the trick and it wouldn't be so unpro solution..
Guest IM_Alarms Posted March 19, 2005 Posted March 19, 2005 anything with an output would do it, you could set the output for 'part set' and use the output voltage to feed the internal sounder. so it needs the + from the output and the switched -ve from the sounder trigger
Guest Posted March 19, 2005 Posted March 19, 2005 LOLor have a decent system which doesnt false alarm in the first place. Problem solved!. 44905[/snapback] Try telling that to the bloke who did the system I went to see today LOL
Guest Posted March 19, 2005 Posted March 19, 2005 LOLor have a decent system which doesnt false alarm in the first place. Problem solved!. 44905[/snapback] I see you having some magic portion in your pic as well..
Guest Posted March 19, 2005 Posted March 19, 2005 I see you having some magic portion in your pic as well.. 44922[/snapback] Georg - Im not so sure that people on here want to know you take a portion!!! unless your real name is Elton...
Guest Posted March 19, 2005 Posted March 19, 2005 come to think off I do have a magic portion but in this case I think you mean potion. 44924[/snapback] LOL rich - thats what I thought he said, see above post lol
Guest Posted March 19, 2005 Posted March 19, 2005 come to think off I do have a magic portion 44924[/snapback] Is that; Large portion <hands behind head> <thrust groin> YES! </thrust groin> </hands behind head>
Guest Posted March 19, 2005 Posted March 19, 2005 i think i had too many of since my typing abilities seem to downgrade..
