Guest Jaarus Posted March 19, 2005 Posted March 19, 2005 Hello all, Let me start off by saying I now absolutely NOTHING about alrm systems but I am having to learn fast as our alarm which was here when we moved in keeps going off by itself.... No bells ringing outside, just a small box which sounds like it has a tiny pneumatic drill inside it near the inside of the front door......and it is really REALLY annoying! I know the cause of the alarms fault...its water The alarm controll panel is situated below the bathroom and occasionally a small amount of water comes down the wall and into the control panel...the alarm either shorts or I suspect assumes someone is trying to tamper withit and off it goes with its pleasant DRDRDRDRDRDRDRDRDRDRDRDRDRDR....untill it dries out I will sort the leak at some point - but for now I just want this bloody alarm to shut up! How can I turn it off? I located the main panel it an airing cupboard but no simple disconnect buttong/switch....I knew I wasnt going to be that lucky! PLLLLLLlease help me - I am going insane! - it must be simple enough if these are sold as home install kits?? Oh and I would get someone out BUT we really cant afford for a professional to be called at the moment
Guest Posted March 19, 2005 Posted March 19, 2005 i suggest you to fix the leak quite soon since there is (might be but most propably is ) MAINS voltage inside the panel...
Guest Jaarus Posted March 19, 2005 Posted March 19, 2005 Thank you both for such speedy replies I will contact my insurance and hope they agree thanks again
