Guest IM_Alarms Posted March 20, 2005 Posted March 20, 2005 chemical bolts are good for confined spaces, you can also get a two part resin from Sika which will stick anything to anything. Can be used to assist the sticking of safes along with bolts. The chemicals will stick a brick onto the face of a wall and you can stand on it in under a minute! As used by burglars
