optima plus 2
Guest confused runcorn
Re optima remote keypads, can anybody tell me how to remove them from wall to decorate behind them. Thanks
Confused Runcorn
It would be easier to decorate around it :( .IIRC the RKP cover just clips off from the bottom, but the pcb may need to be removed to access the screws that hold the backplate to the wall.Removing the cover will create a tamper alarm.
I'd agree with Fastcar.
You "should" be able to reset the tamper alarm with your code, if you do remove the keypad.
It would be easier just to decorate up to it though.
If you don't know......ask.
Decorate over the keypad , and make diagonal cuts to each corner , then , fold back the little triangles,and cut off the excess paper before smoothing up to the key pad. :yes:
46150[/snapback]
Decorate over it and leave the paper there, ITS AN OPTIMA !!!!
Smokie :ninja::roflmao:
Thanks for reading my posts, however insane they may be.
Just remember, 'Success is Built on Commitment, Hard Work, saying F**K it once in a while and most of all LUCK'. Be Happy
simon@sgssystems.com
SGS Systems Web Site
