Guest E Lamb Posted March 31, 2005 Posted March 31, 2005 I have recently moved into house with OptimaXL4 with no instructions. I have seen a copy of pdf of instructions from other posted 'help' enquiries, however they dont help in my situation. Alarm was set off accidently via panic button but I cannot get back to 'day' by pressing reset button. Red 'attack' light is still showing (and power light), but no strobe or alarm sound. Any suggestions?
bellman Posted March 31, 2005 Posted March 31, 2005 I have recently moved into house with OptimaXL4 with no instructions. I have seen a copy of pdf of instructions from other posted 'help' enquiries, however they dont help in my situation. Alarm was set off accidently via panic button but I cannot get back to 'day' by pressing reset button. Red 'attack' light is still showing (and power light), but no strobe or alarm sound. Any suggestions? 46190[/snapback] It won't reset until you clear the cct fault, check to make sure the panic button has been reset. Until this is done it wil lock in attack mode. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
whistle Posted March 31, 2005 Posted March 31, 2005 I the little window in the front of the PA button is green its reset if its red you need to put the small key in and turn 1/4 turn until the window turns green. If this dont work you may have a cable probem or a faulty button you will need to gat an engineer to check it out for you.
