jon london Posted March 31, 2005 Posted March 31, 2005 Hi all, whats evryone using dual com / red gsm. pros and cons and floors in the product. We started with the dual com as the primary path was the radio but having probs with coms faults with bad radio sig and bit error rates. went over to red gsm but again the gsm is not stable in our area of somerset. Thinking of investing in some top quality pigeons , they would much more reliable
datadiffusion Posted March 31, 2005 Posted March 31, 2005 And what area of Somerset are we talking about here 46234[/snapback] 2 Miles out of Bath City Centre if your with T-Mobile, grr...!! Stu. So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Guest Peter James Posted April 1, 2005 Posted April 1, 2005 Dcom is better than most if you have a signal, but no good if you havent. The Bers can be affected by dect phone amplifiers and repeaters take a look at the dcom ant position compared to any of these products. Pete
Smart Electrics Posted April 1, 2005 Posted April 1, 2005 If you feel brave you could try taking a bit of the outer sheath of the coax near the Arial base and using a 2 foot square piece of thin (approx 2mm thick) conductive metal plate and connect the brade to make a ground plane. Gives increased sig strength and quality.
morph Posted April 2, 2005 Posted April 2, 2005 If you feel brave you could try taking a bit of the outer sheath of the coax near the Arial base and using a 2 foot square piece of thin (approx 2mm thick) conductive metal plate and connect the brade to make a ground plane. Gives increased sig strength and quality. 46523[/snapback] And when it messes up will your insurnace cover you If we were meant to do this wouldn't it be included in the box Smarty
Smart Electrics Posted April 2, 2005 Posted April 2, 2005 And when it messes up will your insurnace cover you If we were meant to do this wouldn't it be included in the box Smarty 46546[/snapback] jUST OVER ENGINEERING
Smart Electrics Posted April 2, 2005 Posted April 2, 2005 Nope. 46548[/snapback] WHY WOULD IT INVALIDATE INSURANCE COLIN
morph Posted April 2, 2005 Posted April 2, 2005 Don't shout!! The product is designed and sold as a package. It has been tested and certified as a package, if you then change the way it works or is assembled, the original certification will not apply. Thus if it fails to perform or there is a problem of any sort with the system, because you have modified the product, the insurnace company would not pay out. Secure Signalling is exactly that its not "Tesco Signalling" you don't simply buy it do what you want eith it, because the signal is poor, start chopping it up. Dualcom are very specific about their product and the positioning of the antenna.
norman Posted April 2, 2005 Posted April 2, 2005 But the bigger ground plane would probably work. Nothing is foolproof to a sufficiently talented fool.
