Guest mikechids Posted April 4, 2005 Posted April 4, 2005 I have a MERIDIAN SMS Messenger. Question about Telephone connection.... In the manual it says the connection are as follows..... TA = Line `A` In TB = Line `B` In TC = Line `A` Out TD = Line `B` Out TE = Telecom Ground How does this relate to the telephone connection from the extension socket numbered 1-6. What goes to where? Thanks Mike
Guest Posted April 4, 2005 Posted April 4, 2005 TA = 5 in master socket. TB = 2 in master socket. TC = 5 in secondary socket. TD = 2 in secondary socket. TE = Well, ground! It's set up for line seize, if you're not using line sieze just connect TA and TB to any socket and disregard TC and TD.
bellman Posted April 4, 2005 Posted April 4, 2005 I have a MERIDIAN SMS Messenger. Question about Telephone connection....In the manual it says the connection are as follows..... TA = Line `A` In TB = Line `B` In TC = Line `A` Out TD = Line `B` Out TE = Telecom Ground How does this relate to the telephone connection from the extension socket numbered 1-6. What goes to where? Thanks Mike 46821[/snapback] TA = Line `A` In TB = Line `B` In are the incoming wires from bt TC = Line `A` Out TD = Line `B` Out are the outgoing wires from the panel to the rest of the sockets around the house. for your purposes, you'll only need to wire the blue /white band and white / blue band to the unit, they connect to pins 2 and 5 respectively Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
