Guest letterick Posted April 5, 2005 Posted April 5, 2005 Hi,in the process of installing a scantronic 9651,not to sure how i should wire the single global tamper circuit. I would appreciate any suggestions.Thanks
ian.cant Posted April 5, 2005 Posted April 5, 2005 there is only one way really, in series. Basically all your tamper cct's are loops and they should be daisy chained together.
Guest Posted April 5, 2005 Posted April 5, 2005 The correct way. You sure you should be installing an alarm? As ian says plus remember every cable should be tamper protected too, not just devices with tamper terminals.
datadiffusion Posted April 5, 2005 Posted April 5, 2005 Hi,in the process of installing a scantronic 9651,not to sure how i should wire the single global tamper circuit.I would appreciate any suggestions.Thanks 46933[/snapback] Dont! Use the FSL and end-of-line resistors option, otherwise you will be spending a whole day faultfinding when the nice man from the gas board drills through a cable. Stu. So, I've decided to take my work back underground.... to stop it falling into the wrong hands
whistle Posted April 5, 2005 Posted April 5, 2005 Why not use the EOL method then evey zone has its own tamper loop. And say use the global tamper for the speaker.
datadiffusion Posted April 5, 2005 Posted April 5, 2005 Why not use the EOL method then evey zone has its own tamper loop.And say use the global tamper for the speaker. 47029[/snapback] Sorry Whistle, Global Tamper is ignored when EOL in use. I know, I was disapointed too! Stu. EDIT: Spelling! So, I've decided to take my work back underground.... to stop it falling into the wrong hands
FASTCAR Posted April 5, 2005 Posted April 5, 2005 The installer manual for the 9651 assumes prior knowledge of installing alarm systems.If this is your first install , I would suggest getting hold of the manual for the scantronic9448 or the Texecom Veritas range , as they have some simplified diagrams regarding global tampers and bell wiring. Its always best to do plenty of reading-up and possibly a bench test before you start putting cables in etc. Post back and let us know how you get on. Regards.
Guest letterick Posted April 7, 2005 Posted April 7, 2005 The installer manual for the 9651 assumes prior knowledge of installing alarm systems.If this is your first install , I would suggest getting hold of the manual for the scantronic9448 or the Texecom Veritas range , as they have some simplified diagrams regarding global tampers and bell wiring. Its always best to do plenty of reading-up and possibly a bench test before you start putting cables in etc. Post back and let us know how you get on. Regards. 47057[/snapback] guys for your advice will be installing soon will post back and let you know how it went.
wheelers Posted April 7, 2005 Posted April 7, 2005 guys for your advice will be installing soon will post back and let you know how it went. 47351[/snapback] Sorry but I dont understand why some of you do not like using the FSL method as this is the future of intruder alarm installations and the most secure way of wiring. When the gas man drills through a cable you wil know exactly which one... Nick
whistle Posted April 7, 2005 Posted April 7, 2005 Could not have said it better my self. Also when the gas man drills the cable its a chargable call-out.
