Guest Gav_b_uk Posted April 6, 2005 Posted April 6, 2005 Could someone ID the following keypad for me and possibly even provide a link to a user manual???
bellman Posted April 6, 2005 Posted April 6, 2005 Could someone ID the following keypad for me and possibly even provide a link to a user manual??? 47067[/snapback] It's an Accord XPC User manual is HERE Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest Gav_b_uk Posted April 7, 2005 Posted April 7, 2005 Thanks for the reply... Quick question.... Can anyone tell me how I can disable this alarm while I service a sender unit on a window....the unit seems to be suffering from condensation...but everytime I try to remove the cover the bell goes off.....
Guest camdec Posted May 5, 2005 Posted May 5, 2005 That is called a Tamper. Unfortunatly it will keep activating every time you remove the lid. You should be able to put you code in and it will silence it. Just make sure that the lid is replace correctly else the tamper will not clear and you will not be able to set the alarm!!!!!
jb-eye Posted May 5, 2005 Posted May 5, 2005 Could someone ID the following keypad for me and possibly even provide a link to a user manual??? 47067[/snapback] You can download the user manual from our web site JB-EYE go to downloads then jb-eye xpcJef Customers!
whistle Posted May 5, 2005 Posted May 5, 2005 Has some one had the jif on that //.National Installer.// rkp ??
