Guest Griffmaster Posted April 8, 2005 Posted April 8, 2005 Hi, I have an Abacus 6 system and I would like to remove the remote keypad for decorating purposes. If I disconnect the remote keypad, I have the engineer code, will the programming be lost or is the information held in the main panel? Thanks.
Guest FSS Posted April 8, 2005 Posted April 8, 2005 Yes all the programming info will be ok , just remember where the wiring goes if you are removing it . if in doubt call your local alarm company. Andy
Stealth Posted April 8, 2005 Posted April 8, 2005 Dont short any ccores together!!!! Chubb Service Engineer
datadiffusion Posted April 8, 2005 Posted April 8, 2005 Dont short any ccores together!!!! 47624[/snapback] I guess you know what you are doing, but disconnect it at the CCU end first! Write down all the colours and dont trust your memory!! Stu. So, I've decided to take my work back underground.... to stop it falling into the wrong hands
