Nexus 8 - 2nd Keypad
Guest jonno2607
Guest jonno2607
I've fitted a second remote keypad to a Lynteck Nexus 8 control panel, but need help. So far I have:
1. Disconnected mains
2. Disconnected battery
3. Connected Live and Neutral (NOT Data) of keypad to control panel
4. Reconnected battery and mains
New keypad displays " n1 " (as Engineers Guide states it should), but I cannot set the new keypads address number. Engineers Guide says just press 1-4 and YES and a confirmation bleep will be heard, but when I do this I get no bleep and the keypad still shows " n1 ".
Should I be connecting the data cable to the control panel 1st? or is there something else I need to do?
I'd be grateful for your words of wisdom!
banghead
Try connecting the data terminal, the engineers guide doesn't say not to connect it.
You are setting at a different address to the existing one aren't you?
And technically speaking, if you've connected a live and neutral to the keypad I'm amazed it shows anything. ;)
Guest aechlin
Have you told the system how many RKP's it has with ref. to Menu 23?
Alistair
Guest jonno2607
Thanks for your help - its now working fine.
