Guest Stuart N Posted April 9, 2005 Posted April 9, 2005 I have a scantronic 9800 and I need to crash the panel because I have forgotten the engineers code. I have an installers guide and it says remove the NVM chip IC8 but it does not exist. The only chip not soldered on the board is the main IC. How do I crash the panel? Thanks
Guest Posted April 9, 2005 Posted April 9, 2005 How do I crash the panel? 47836[/snapback] Simple answer, you call an alarm co. We don't give out information on defaulting alarm panels in the public areas I'm afraid.
Guest Stuart N Posted April 9, 2005 Posted April 9, 2005 Simple answer, you call an alarm co.We don't give out information on defaulting alarm panels in the public areas I'm afraid. 47839[/snapback] ok Thanks for the advice.
Guest Stuart N Posted April 10, 2005 Posted April 10, 2005 Is there another area in which I can receive some information? It must be obvious that I have an installers guide to know the standard way of refreshing. Calling out an alarm company is an unecessary option. I installed it in the first place, just didnt need to do this action then. Any help is appreciated. Thanks
norman Posted April 10, 2005 Posted April 10, 2005 Its at the rear of the installation manual. Nothing is foolproof to a sufficiently talented fool.
Guest Posted April 10, 2005 Posted April 10, 2005 Although if you can't decipher the manual then should you really be playing with the system?
Guest Posted April 10, 2005 Posted April 10, 2005 stuart n 2 questions when did you install it and where abouts are you ???
Nova-Security Posted April 10, 2005 Posted April 10, 2005 It must be obvious that I have an installers guide to know the standard way of refreshing. 48092[/snapback] There is only one way of crashing a 9800 (the standard way) and if you have the engineers manual it is deffently in that. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest Stuart N Posted April 11, 2005 Posted April 11, 2005 There is only one way of crashing a 9800 (the standard way) and if you have the engineers manual it is deffently in that. 48097[/snapback] My 'modern' installers guide says IC8 but it does not exist. The board is issue 12. I am in Mcr. I am sure you guys know how to do it in the event the IC8 chip does not exist. Can someone email me with the answer?
Guest Stuart N Posted April 11, 2005 Posted April 11, 2005 My 'modern' installers guide says IC8 but it does not exist. The board is issue 12. I am in Mcr. I am sure you guys know how to do it in the event the IC8 chip does not exist. Can someone email me with the answer? 48108[/snapback] It has been in for about 11 years
