Blu STU
Guest mmh
Hi,
I've Veritas panel with a Blu STU.
The Blu STU was playing up and I've been told may need replacing.
Do these units go wrong often, only had it a year or 2?
How much do these normally cost?
Thanks,
M
Check the warranty label it may still be under warranty, like everything else it will either last a lifetime or a couple of years, no real reason for failure.
I think it maybe out of warranty, only just though.
How much do they cost to buy?
Thanks,
Mo
Thanks,
Mo
48568[/snapback]
We cant tell you that im afraid.
Dave Oxendale
York based security systems engineer.
48569[/snapback]
Why am I not allowed to know?
Just wanted to know the rough price of the unit itself so I am aware when getting quotes for one to be installed, should this one fail.
It depends on the modelcand type of RedCare but they retail from around £180.00 upwards.
Usual faults are bt engineers meggaring the telephone line, and lightning strikes.
Have you had ADSL Broadband recently fitted? if you do not have a filter fitted this will effect how your STU works.
Regards Peter
48642[/snapback]
At last thankyou for the information very useful, BTW it's a Blu STU 8
The STU not being able to be monitored most probably was down to BT engineers working on the line.
I've had broadband for a while but have had extention sockets fitted off the Master socket.
In what way might the lack of adsl filter affect the STU?
Thanks,
Mo
Is it faulty or just in line fault? Have you got your arc to try and up the stu?
if the stu if down both LEDs will be flashing on and off
Are you getting churps on the line and last but not least is the red care on the correct line??
48670[/snapback]
The STU is now up but there was a fault somewhere either on the line or the unit.
There were a lot of chirps on the line but now it's OK.
The volts on the line were around 16v, I believe the normal volts on a line should be between 40 and 50.
Sounds like a BT fault to me although they will never admit to it.
Just as well you did not spent £180 upwards on a new stu :no:
