Blu STU
Guest mmh
Sounds like you have a high resistance fault on one of the legs A or B. (Semi disconnection) Have you tried reporting your line as faulty. You can report the fault online.BT Faults
I doubt the Unit has been damaged by a meggar as the lightning arrestor would of gone in the NTE and you would have no dial tone or Voltage.
48690[/snapback]
Apparently BT upped the voltage on my line, so I've been told. This was after it was reported.
I'm just trying to understand what might have caused the fault as I believe the redcare STU units are meant to be very reliable as by their nature being used to monitor valuable assets etc they need to be so.
48696[/snapback]
External Influences (BT) get my vote!! but you will never prove it, although the unit works now and what did you change other than upping the stu.
48696[/snapback]
Do you mean they have increased the gain. The voltage will never go up if its a PSTN line 54 Volts
Agh just noticed you said you have had extension installed of the master. Was this done by yourself or BT. Like I said HR diss. Red care is chirping a lot because the line is experiencing disconnections temporarily. If you have red Care you should be covered by total care. If you report it and the faults operator or system does not see a fault push it through and explain you are willing to pay for call out if it is proved to be your fault. I am sure it will be in the network. What does your alarm company say.
48704[/snapback]
It's one extension off the master by myself. I've had it a while no problems. I'm a network designer so not much chance of me going wrong with a simple extension, Only connected to the user attachable part of an NTE5 socket.
I think BT did increase the gain and all has been fine since. I'm not quite sure what increasing the gain means.
Thanks
Gain increase is like turning the volume up from the exchange. It is used on long cable runs when customers complain about low volumes on speech. I was not suggesting that you have caused the fault yourself as merely suggesting that while you had the face plate that you didn
Thanks
48709[/snapback]
Shouldn't you be getting your alarm company to take this issue up with BT for you as they are providing a service and if it doesn't work, you would be going back to them to find out why. Or do you have a problem with what they are telling you?
