Guest kjud Posted April 14, 2005 Share Posted April 14, 2005 Hello there, I've just joined the forum to get some advice about installing two camera's to monitor my workshop. I've looked into diffrent cameras and the b&w bullet cam has been reccommended. A friend of mine has these to monitor his home and provide a good picture over the area required at the workshop. I've also downloaded the 'Gotcha multicam' free thirty day trial and like the software. It has all the features i would require as i plan to use the works PC to record images. The main query I have is, would it be difficult to get the camera signal into the pc, in a format the gotcha software would recognise, and would I have to buy a specific pci card, or other device? Any help would be greatly appreciated. Regards, Kev. Link to comment Share on other sites More sharing options...
Rich Posted April 14, 2005 Share Posted April 14, 2005 Depending on what the software you has requires as a video signal, but probably any format a video capture card can supply. You will most likely need 2 video capture cards though. You could use something like a vista smarttel 2 channel transmitter. http://www.norbain.co.uk/products/ref:0084610/ use a lan adapter with it and connect it straight into your PC network socket or router. Link to comment Share on other sites More sharing options...
