veritas 8c
Guest ianleslie
Guest ianleslie
VERITAS 8C
hi I really hope someone can help. Ive had this system for 1 year, it started to bleep every time i passed a sensor. I got a guy out he stopped the bleep however now the alarm go`s off every time I come home without giving me time to unset it .aaaaaahhhhhhhhhhh. HELP PLEASE
This is because the sensor you are triggering on entry (either a door contact or passive) is not programmed for exit entry to give you time to switch the system off.
You will need an engineer to reprogramme it for you.
Post your location as i'm sure there will be a forum member close to you
Regards
Bellman
If this wasnt long ago call him back to put your system right (F.O.C.), if its been a while do as Bellman says.
