Guest Rav Posted April 23, 2005 Posted April 23, 2005 Hi - any help would be much appreciated. I have a Optima XM6 alarm system. I recently switched the mains power off to do some other electrical work and when i switched it back on, the power light came on but would do nothing else!!! Anyone have any idea what it could be? I didn't touch any of the alarm cables when I did my electrical work. Thanks.
Guest Posted April 23, 2005 Posted April 23, 2005 Post your location and maybe someone on here could assist you further. The panel sounds as if it needs defaulting,as said by richl, this is not an end user procedure and really an engineer should take a look. Sorry, I know its not what you want to hear Dave.
Guest Posted April 23, 2005 Posted April 23, 2005 you got the tamper circuit open link out bell return, gobal tamp & lid tamp bingo it's alive
Guest Posted April 23, 2005 Posted April 23, 2005 or have a better quality alarm system installed. 49881[/snapback] ade's products are ok just stay away from the rochdale rubish (yes I know they moved)
Deltaseven Posted April 23, 2005 Posted April 23, 2005 you got the tamper circuit openlink out bell return, gobal tamp & lid tamp bingo it's alive 49918[/snapback] Hmmm. Not sure that is a long term solution...
j.paul Posted April 23, 2005 Posted April 23, 2005 Hi - any help would be much appreciated.I have a Optima XM6 alarm system. I recently switched the mains power off to do some other electrical work and when i switched it back on, the power light came on but would do nothing else!!! Anyone have any idea what it could be? I didn't touch any of the alarm cables when I did my electrical work. Thanks. 49867[/snapback] Sounds like you have a faulty battery in your panel and the system has lock out when you put the power back on.. A basic service and a new battery should sort it... There are no stupid questions, but there are a LOT of inquisitive idiots.
Nova-Security Posted April 23, 2005 Posted April 23, 2005 ade's products are ok just stay away from the rochdale rubish (yes I know they moved) 49919[/snapback] Hmmmmm, your right about the rochdale rubbish but to be honest rubbish if far to good, something strong may have been better. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest Fayraz Hussain Posted July 1, 2005 Posted July 1, 2005 This morning I woke up to find I have the same problem, the power light is on but nothing else and the bell is ringing outside but the strobe is not flashing and the keypad on the panel does not respond? I had to disconnet the bell outside to turn it off, anyone got any ideas?
FASTCAR Posted July 1, 2005 Posted July 1, 2005 Hi , Your flat battery has probably fried your charging circuit.Best bet is to get an alarm eng. round to check that the panel is still serviceable. Regards.
Guest RICHL Posted July 1, 2005 Posted July 1, 2005 anyone got any ideas? 58932[/snapback] have a better quality alarm system installed. 49881[/snapback]
