Mavrick_001 Posted July 3, 2005 Posted July 3, 2005 Umm, panel battery sounds flat.... as others have said!! These systems don't take alot of abuse, suggest getting someone out there to have a look at fixing it if it's not already stuffed. Otherwise if your content with fixing it yourself good luck!!!!!! I think someone had asked you to put your location on to see if someone was in your area to help out, we can't tell you how to default your panel because that would just be wrong.... we'd be telling every man & his dog how to bugg*r up everones alarm, if you see where we're comming from. If you want try powering down and replacing the panel battery, maplin do them.. (costly) but if you want to have ago yourself, put lid on and press reset, if it still plays up get someone out there is your best bet...... And yes you will prob have to pay for it!! CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
