Advice on detector
Guest Pedro
Guest Pedro
I need a detector capable of working outdoor, in a place with very high temperatures in summer and surrounded by tress and bushes.
I had first thought about PIRs, but now I am doubting.
Is it possible to find such a detector?
50398[/snapback]
What do you need the Detector to switch on outside ?
An infrared beam pair may be suitable? They can be shaded from the sun for less false alarms.
If you don't know......ask.
Hell yeah brian, spec sheet says -10c to 50c so that should cover the hottest days in Spain comfortably. They dont cause any problems here in the summer and we have silly weather!
I know they're good, but you never had problems with them triggering in strong and or direct sunlight? I know I have.
50474[/snapback]
Your confident it hasnt been wildlife or insects?
50522[/snapback]
Well, not in every scenario, but definitely had constant activations from redwalls in direct sunlight. Sun goes down, activations stop.
The ARC were pretty good at pinning down activations, and when they're constant with nothing captured and preset is looking towards the sun, I'm pretty confient that it can cause problems.
