Veritas R8 Plus problem
Guest Souljim
Guest Souljim
I recently had a problem with my alarm system (Veritas R8 Plus) after a bulb blew and tripped the fuse. On resetting the fuse I noticed zone 1 was lit on the keypad and the keypad itself was completely dead (the bellbox light was also flashing but no alarm sounding).
I've since managed to get the keypad working zone 1 is no longer lit and the light on the bellbox is no longer flashing. In the process though I've activated the tamper so cannot now set the alarm.
The original installer is unfortunately not welcome after upsetting my wife on an earlier late night visit when we had a problem so I'm not sure what to do.
Any advice would be very welcome.
Souljim
Post your location, someone nearer to you may be able to help.
Dave.
Souljim
50491[/snapback]
Sounds like another panel with a battery problem :smash:
As DNS Says
Guest Souljim
As DNS Says
50496[/snapback]
I live In Hull. Checked battery which seems fine. I'm guessing the system needs resetting and can only be done if I have the original engineers code.
50505[/snapback]
Hi Mate
you probably wont get a hold of the engineer code from the installer.Best bet is to ask someone to come and have a look at it
housty
Houston Security Systems Ltd
Intruder alarms
CCTV
Door entry
Fire protection
Networking
SSAIB Approved
Guest RICHL
50505[/snapback]
How did you check the batt Souljim?
Guest Souljim
50534[/snapback]
My brother checked the battery. He's a NICI registered electrician so I assume he knows what he's doing?
50648[/snapback]
Not neccesarily......
Your best bet would be to get an engineer out to it as it could be several things. A decent service never goes amiss anyway.
