Guest marky-b Posted April 26, 2005 Posted April 26, 2005 hi, i have got a securit 700L. i fitted it some years ago, i havent had any probs with it, i have a top up elctric meater, so when it runs out, the alarm goes off. i have repaced the battery in the alarm box, and the fuse. it still goes off. i carnt find any faults with the alarm system...... i use the alarm with sms system too. i have 6 pirs and 4 door mc. and i dont get many fauls alarms.. can anyone please help me too find out whats the problem...... marky-b banghead
Guest marky-b Posted April 26, 2005 Posted April 26, 2005 Sounds to me like your battery charging circuit is kapput, have you tried putting a meter on the battery leads with the battery disconnection to check if theres any charging voltage. How long was the previous battery in place for. 50512[/snapback] the battery has a date on it, 7/11/96. i have replaced it 2day, and the fuse is ok. i havnt checked the leads, i dont have anythink too check it with, if it doesnt work 2morrw nite then i will replace the end user. for what it costs it nowt, i have had the alarm for 10 years. thing is i dont want too replace the remote keypads.... marky-b scunthorpe
whistle Posted April 26, 2005 Posted April 26, 2005 Not sure but i have one in my garage with a rkp. Didnt they make a 800l ??
Guest RICHL Posted April 26, 2005 Posted April 26, 2005 yeah the 800L plus a few other rebadged sparky special varients.
Guest marky-b Posted April 27, 2005 Posted April 27, 2005 yeah the 800L plus a few other rebadged sparky special varients. 50545[/snapback] i have looked at my alarm. the fuse has blown, i replaced the fuse and is working for now........ i still think theres a problem with it so i am going too test it again 2morw nite marky
Mavrick_001 Posted April 30, 2005 Posted April 30, 2005 They changed the 700l to 800l. The 800l has an extra zone. If you changed the panel the 700 keypads will need changing as well. They are exactly the same size and little diffecrence other than zone 8 being an there. The new circuit board will fit in the old panel so it's quite stright forward if you know what your doing. As with the others it sounds like the charging cct is b***rd. They're not the most expensive bits of kity so won't cost an arm & a leg CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
Guest marky-b Posted May 1, 2005 Posted May 1, 2005 They changed the 700l to 800l. The 800l has an extra zone. If you changed the panel the 700 keypads will need changing as well. They are exactly the same size and little diffecrence other than zone 8 being an there. The new circuit board will fit in the old panel so it's quite stright forward if you know what your doing. As with the others it sounds like the charging cct is b***rd. They're not the most expensive bits of kity so won't cost an arm & a leg 50877[/snapback] hi ya. where do i get the 800L from? and would be better bying a difrent make? and newer? ie: led keypads???
Mavrick_001 Posted May 2, 2005 Posted May 2, 2005 gardiner security, national company if they'll sell to you, usally trade. Otherwise city electrical factors, they will be more expensive. Call directory enquirys for your local branch of either. Oh by the way, city rebadge them as challenger...... Me.... I'd go for a eurosec cp8l myself..... you may struggle getting hold of one of these...... please ask gardiner security for one because I'd just love to see what they have to say lol CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
Guest IM_Alarms Posted May 2, 2005 Posted May 2, 2005 Menvier 590 - LCD keypad etc, good price - Gardiners also
Mister_Dave Posted May 3, 2005 Posted May 3, 2005 Securit 800l HERE Dave Oxendale York based security systems engineer.
