Remove pir off system
Guest Topman
Guest Topman
All
Need help, i have the Veritas R8 secruity control panel, which i've had about 8 years. we had a PIR in the conservatory, the converatorty has now been pulled down and i want to disconnect the PIR wires from the box.
i've tried already but the warning buzzer sounds when the tamper wires are disconnected, then when the buzzer is reset, on the R8 panel the tamper light stays alight.
how do i remove the complete PIR from my system :(
cheers
chris
Post your location topman - someone on this forum near to you, may be able to help :)
