Guest Posted April 30, 2005 Posted April 30, 2005 i think i should ring up ibm and take the p*** 50922[/snapback] You're into that then are you? I haven't come across a laptop, or a PC, yet that has BIOS password on as default, you must be lucky.
Guest Posted April 30, 2005 Posted April 30, 2005 You're into that then are you? now how do i get out of that one....
Guest Posted May 1, 2005 Posted May 1, 2005 sorry guys, i have an ibm as my laptop and anyone is free to try 1234 or anything similar or more complicated if they want to make a bet of guessing or calculating it out before the data is irrelevant...
breff Posted May 2, 2005 Posted May 2, 2005 What model 390 is it Eng? (eg 390e) I can send you the hardware maintenance manual in pdf if you want. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest jack zhong Posted October 3, 2005 Posted October 3, 2005 I just faced this problem with my IBM Thinkpad and would be great appreciated if you could send a copy of mantanence manual.
breff Posted October 3, 2005 Posted October 3, 2005 PM me with your email address and the exact model The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
