Modern Alarms Series3200
Guest ashas
:o HELP!, I have just moved into a property that has a Modern Alarm, Series 3200 System installed but there is no code for the system.
Can somebody please supply me with a manual for this system or please advise on how to reset the alarm and enter a new code.
  • 3 months later...
Guest maximum protection north east
the 3200 panel is the same as the scantronic range of panels, it's either a scan 9800 or a 9600.if it's got an led keypad it's a 9800 if its got an lcd keypad it's a 9600.The programming is identical between the 3200 and the other. hope this helps :blink:
