ADE optima compact manual
Guest rwybrow
Guest rwybrow
Dear All,
I have recently moved in to a house with an ADE optima compact alarm system but the people who owned the house before did not leave the manual. They did leave basic intructions, but i would like to have a copy of the maunal.
I have been onto the ADE website, but they do not stock this as an online manual.
Does anyone have a copy that they can send me? or does anyone know how i can get one?
Thanks alot
Rob
  • 1 year later...
Guest andyuk71
Here you go then.
Optima_Compact_User.pdf
Hi, I found this site through having the same problem as rwybrow in the previos post, though my only information was the previous alarm code. The manual pdf file has enabled me to change my code, many thanks, though my alarm is a slightly different model. It too is an ADE Optima Compact though it only has 6 zones and there's no reference to G3. Do you know where I might be able to download the manual for my particular model? Thanks again, Andy.
  • 6 months later...
Hello,
I too require the manual after moving into a new house however, after signing up to this website, I still can't download the manual. Could someone please upload it or email me it to:
Many Thanks
Stephen
  • 9 months later...
Hi
I too have just moved in to a property with an ADE Optima Compact 6 Zone however mine was installed in 1998 has anyone got the manual for one that old or is it basicly the same as the G3
Hi
Here ya go .....
Optima_Compact_6_Operating_Instructions_.pdf
  • 2 months later...
Here ya go .....
Hello
Thank you for the Optima compact manual.. I have an Optima compact too and I want to turn it off to work on the mains but once the mains are turned off the alarm goes off. How can I silence it please?
There is no provision for this in the manual
Best regards
Hello everyone
Thank you all for the Optima compact manuals and advice.. I have an Optima compact too and I want to turn it off to work on the mains but once the mains are turned off the alarm goes off. How can I silence it please?
Best regards
Guest anguscanplay
Hello everyone
Best regards
it shouldnt - the alarm battery is faulty, replace this first
Hi
I meant that once I turn the mains off, the alarm starts and I couldn't stop it. I need to switch the mains off to upgrade the switch board and it could take a days job.. I cannot keep the alarm sounding. There must be a swtich off to the system.
Now if I turn off the mains and disconnect the battery it may do the job but then what is the default code to rearm the alarm please?
fadi
Hi
fadi
1) No there is not
2) We will not provide such information
See here - http://www.thesecurityinstaller.co.uk/comm...mp;f=2&id=8
Your alarm is working as designed to.
Please do not ask for bypassing, disabling or silencing info again.
Thank you.
C.
