Guest nirvana Posted May 15, 2005 Posted May 15, 2005 Hi I installed an SL Compact Alarm a few years ago (with a little help). It's been switched of for ages though (since getting a cat as I've lost teh manual and forgot to to omit zones. Anyhow killed power to the alarm today as had to get into a sensor to re-attach it to the wall - power came back on - alarm went off - cleared it with the code - problem is now the tamper light is on along with the power light - but nothing else seems to work - any ideas how to clear the tamper/where i could get a copy of the instruction sheet. Thanks - Angie
FASTCAR Posted May 15, 2005 Posted May 15, 2005 Hi , the SL is basically the same as the Optima XM, and the user manual is knocking about this site somewhere.You have a tamper fault which would most likely be on the last thing you touched , ie. the sensor.Make sure the lid is on properly , and that the control panel lid is closed. Have you had the battery and charging circuits checked recently?. Regards.
Guest nirvana Posted May 15, 2005 Posted May 15, 2005 Hi , the SL is basically the same as the Optima XM, and the user manual is knocking about this site somewhere.You have a tamper fault which would most likely be on the last thing you touched , ie. the sensor.Make sure the lid is on properly , and that the control panel lid is closed. Have you had the battery and charging circuits checked recently?. Regards. 53346[/snapback] Thanks, I'll have another look at the sensor.
WatchdogSecurity Posted May 16, 2005 Posted May 16, 2005 Hi I installed an SL Compact Alarm a few years ago (with a little help). It's been switched of for ages though (since getting a cat as I've lost teh manual and forgot to to omit zones.Anyhow killed power to the alarm today as had to get into a sensor to re-attach it to the wall - power came back on - alarm went off - cleared it with the code - problem is now the tamper light is on along with the power light - but nothing else seems to work - any ideas how to clear the tamper/where i could get a copy of the instruction sheet. Thanks - Angie 53288[/snapback] If the keypad is dead, then its deinately a tamper, check the spring under the cover if you have removed it, Cant remember if the SL had an NVM.. saying that ive seem XL6s and above loose there memory many a time... Dean Watchdog Security (Manchester)
