Monteey Posted May 16, 2005 Posted May 16, 2005 If the panel supports End Of Line resistors, you might be able to facilitate tamper, but you need the other fault sorting first I would seriously doubt if the said numpties have bothered to fit anything half decent let alone a panel that supports EOL Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Guest Posted May 16, 2005 Posted May 16, 2005 I would seriously doubt if the said numpties have bothered to fit anything half decent let alone a panel that supports EOL 53507[/snapback] LOL I know - I was just trying to think of alternatives should the need arise
WatchdogSecurity Posted May 17, 2005 Posted May 17, 2005 Do you know if the bell is definately working properley.???? try it with a battery toi see if its that, that is the problem. Dean Watchdog Security (Manchester)
Truss and France Posted May 18, 2005 Posted May 18, 2005 Hi If its only 7-9m from the panel and you think another core is damaged, then why dont you just sling in a bit (temp.)of cable between the panel and the bell to check to see if it is a cable fault or sounder fault, sounds like a faulty sounder to me. Good luck
