Security Technician Posted May 17, 2005 Posted May 17, 2005 Hi I need to replace the line cord in my tele 300a butt phone, the one that is in it the moment is a red and black braided cord, the one i am replacing with is a standard replacement line cord with bt 431 plug the connections inside the butt are marked tip and ring, can anyone tell me which wires on the bt cord i need to connect up Thanks
Guest Posted May 17, 2005 Posted May 17, 2005 Normally the outside two or 2+5 the ouside often blank connector strips would be 1 + 6 if you get my drift Didnt know you are a moderator on another site mate
Security Technician Posted May 17, 2005 Author Posted May 17, 2005 ok mate i wil give it a try and see how i get on Thanks for that
Simon_B Posted May 17, 2005 Posted May 17, 2005 Normally the red and white wires are " tip and ring" or UK speak A leg and B leg. Use the outer pair of the 431a plug as per previous post. or if it is a 631a plug (6-pin) then it is pin 2 and 5. Simon ToneTel Telecom www.tonetel.co.uk
