help me please
Guest gorin
Guest gorin
i have removed a smoke alarm from my accenta g3 alarm system and when i have powered it back up the alarm goes off and i cant stop it when i put the code in, it sounds right but the alarm does not stop i have tried linking out the tamper and the zone i removed it from but it is no different, what can i do
Could be a blown fuse?
When you say "alarm goes off", which bit, the internal sirens or the internal and external? Any lights on the keypad?
Not trying to be smart but put the smoke detector back up. Failing that call an engineer the fire zone is probably a 24 hour zone.
54077[/snapback]
When u say goes off, do you mean the external bellbox or the panel itself?
Regards
Bellman
Guest gorin
54077[/snapback]
all sirens go off and the only light on the keypad is the power light
Presuming you mean your putting the code in the RKP - sounds like a blown fuse on the rkp line - if the leds dont light on the keypad then its that.
in that case it sounds like the panel has defaulted.
try using 1234 as the code, if that silences it then it needs to be reprogrammed.
Regards
Bellman
Guest gorin
54079[/snapback]
i have tried that but it wont let me into the system to program it
Guest gorin
Regards
Bellman
54084[/snapback]
tried that i cant get into the sytem at all
If the BACKLIGHT is off on the rkp its the fuse still.
