Guest gorin Posted May 21, 2005 Posted May 21, 2005 Presuming you mean your putting the code in the RKP - sounds like a blown fuse on the rkp line - if the leds dont light on the keypad then its that. 54083[/snapback] the power light comes on the keypad and when i punch the code in each number still chimes i have checked the fuse and its ok
Guest Posted May 21, 2005 Posted May 21, 2005 The default user code on one of those is 0123 by the way.
bellman Posted May 21, 2005 Posted May 21, 2005 when u powered the system down did you do mains and battery or just mains? Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
bellman Posted May 21, 2005 Posted May 21, 2005 The default user code on one of those is 0123 by the way. 54089[/snapback] oops just read the eng manual and found that out lol. sorry, my bad. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
robert99d Posted May 21, 2005 Posted May 21, 2005 all sirens go off and the only light on the keypad is the power light 54082[/snapback] Is it the normal siren sound or is it pulsing on and off?
Guest Posted May 21, 2005 Posted May 21, 2005 Is it the normal siren sound or is it pulsing on and off? 54093[/snapback] I like the way your thinking - If it was a 24hr fire zone it would go off straight away -although the cust code should still silence it though
robert99d Posted May 21, 2005 Posted May 21, 2005 I like the way your thinking - If it was a 24hr fire zone it would go off straight away -although the cust code should still silence it though 54096[/snapback] Sometimes lock you out on 24h fire zone don
Guest Posted May 21, 2005 Posted May 21, 2005 Its poss, but the user code or default code should still silence the alarm even if it were in a tamper condition or fire alarm 24hr zone - unless the bells in tamper with a duff sab - so when he juices the panel its feeding the siren whilst in tamper condition or something???
Nova-Security Posted May 21, 2005 Posted May 21, 2005 On some G3 the first ones if a fire zone was active then the sounders would not stop until the zone had cleared www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest Posted May 21, 2005 Posted May 21, 2005 On some G3 the first ones if a fire zone was active then the sounders would not stop until the zone had cleared 54107[/snapback] Really, so as robert suggested by his post it could still be due to the disconnect of the S/A - in that case he just needs to link out the zone in the panel that he took the S/A's wires out of.
