Guest gorin Posted May 22, 2005 Posted May 22, 2005 Really, so as robert suggested by his post it could still be due to the disconnect of the S/A - in that case he just needs to link out the zone in the panel that he took the S/A's wires out of. 54109[/snapback] how do i cancel the fire zone
Guest Posted May 22, 2005 Posted May 22, 2005 how do i cancel the fire zone 54258[/snapback] The easy way for the moment is to just put a wire link in the space you took the two original wires from the connectors in the panel.
Guest gorin Posted May 22, 2005 Posted May 22, 2005 The easy way for the moment is to just put a wire link in the space you took the two original wires from the connectors in the panel. 54265[/snapback] tried that it didnt work it had no affect
Guest Posted May 22, 2005 Posted May 22, 2005 I cant think of anything else for you to try mate sorry. It may be time to find someone local to you and get them to give you a quote. Dave.
Guest gorin Posted May 22, 2005 Posted May 22, 2005 Really, so as robert suggested by his post it could still be due to the disconnect of the S/A - in that case he just needs to link out the zone in the panel that he took the S/A's wires out of. 54109[/snapback] i have tried linking out the zone and it is still the same is there any way i can restore factory settings even though it wont let me in the system
Guest Posted May 22, 2005 Posted May 22, 2005 i have tried linking out the zone and it is still the same is there any way i can restore factory settings even though it wont let me in the system 54276[/snapback] As been discussed on here before my friend, we cant disclose that information in a public forum, and also to non-trade members due to the security implications etc. Sorry about that, Dave.
robert99d Posted May 22, 2005 Posted May 22, 2005 What exactly did you do to disconnect the fire detector
Guest gorin Posted May 22, 2005 Posted May 22, 2005 What exactly did you do to disconnect the fire detector 54280[/snapback] what happened was i needed to disconnect the sa so i oppened the panel and the alarm didnt go off which i found strange but when i looked at the tamper spring it was stuck up so when i touched it it sprang down and the alarm went off so i removed all power inc the battery and i disconnected the sa from zone 8 and out off the tamper loop i then linked out zone 8 and reconnected the power since then i cant stop the alarm unless i remove the power
Guest Posted May 22, 2005 Posted May 22, 2005 DID you try the 0123 as the user code or have you still been trying 1234?
Guest gorin Posted May 22, 2005 Posted May 22, 2005 DID you try the 0123 as the user code or have you still been trying 1234? 54303[/snapback] i tried both would you sugest stripping the panel down putting all the links back and see what happens then
