SL Compact
Guest gray
Guest gray
HI
I have just moved house and they have a SL Compact alarm but have not left the instructions!! Does anybody know how tyo change the Alarm code at all or have the manuall?
Thanks a lot
If you dont know the original user code or you wernt given one when you moved in then you will need to default the panel, and we cant tell you how to do that for security reasons sorry.
So you will need to know what the code was.
Guest gray
Thanks
Sorry - Should of read the rules! I tried searching but must not of been doing it right!
I have the current code that we use so i will look at the other thread
Thanks again
Thanks
Thanks again
54309[/snapback]
OK mate Im sorry for being harsh, but thats the way it is :(
