jb-eye Posted May 24, 2005 Posted May 24, 2005 I did a search on this subject without any luck. I have a number of panels signalling on NTL lines. Two of my systems have recently had the same problem. They send a signal and then the telephone lines go dead. if you disconect the alarm the line clears and the phones and alarm go back to normal. Now i remember NTL used to be 30 volt systems and we used to have problems, but these are now at 40v. Can anyone throw any light on the subject. (aritech and microtech panels) Thanks Jef Customers!
Guest Posted May 24, 2005 Posted May 24, 2005 I just want to check the obvious have you tried with a handset connected to make sure its not a resticted line or summit?
jb-eye Posted May 24, 2005 Author Posted May 24, 2005 I just want to check the obvious have you tried with a handset connected to make sure its not a resticted line or summit? 54607[/snapback] Butt direct on line no probs. also escalated to manufacturers, no responce as yet. The thing being both these systems started life as BT.jef Customers!
ian.cant Posted May 24, 2005 Posted May 24, 2005 I did a search on this subject without any luck. I have a number of panels signalling on NTL lines. Two of my systems have recently had the same problem. They send a signal and then the telephone lines go dead. if you disconect the alarm the line clears and the phones and alarm go back to normal. Now i remember NTL used to be 30 volt systems and we used to have problems, but these are now at 40v. Can anyone throw any light on the subject. (aritech and microtech panels) Thanks Jef 54605[/snapback] I had something very similar with a digi on a Teleworst line. You have to ask the line operator (NTL) to do something but im buggered if i know what it was now as it was over a year ago. They have to switch something off or on or turn it inside out or summat, cant think of the technical term! Try asking the ARC tech help, im sure they will be able to be more specific than i ever will.................shrragginfragginrubbishy alarms i hate em!
jb-eye Posted May 24, 2005 Author Posted May 24, 2005 I had something very similar with a digi on a Teleworst line. You have to ask the line operator (NTL) to do something but im buggered if i know what it was now as it was over a year ago. They have to switch something off or on or turn it inside out or summat, cant think of the technical term!Try asking the ARC tech help, im sure they will be able to be more specific than i ever will.................shrragginfragginrubbishy alarms i hate em! 54613[/snapback] Switch the Eside??Jef Customers!
breff Posted May 24, 2005 Posted May 24, 2005 This may have nothing to do with it ,but............ Ive got an NTL line and to get my Premier to text me I've had to set it to pulse dial, it just will not work on DTMF. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
jb-eye Posted May 24, 2005 Author Posted May 24, 2005 This may have nothing to do with it ,but............Ive got an NTL line and to get my Premier to text me I've had to set it to pulse dial, it just will not work on DTMF. 54628[/snapback] Intresting! tanks for that.Jef Customers!
ian.cant Posted May 24, 2005 Posted May 24, 2005 Something along the lines of what Breff said i think, seems to ring a bell banghead I honestly cant remember for sure.
Guest RICHL Posted May 24, 2005 Posted May 24, 2005 Smarty posted something on this subject a while back - IIRC NTl are still sopposed to be 50v, and if need be they can increase this where it is too low.
Smart Electrics Posted May 24, 2005 Posted May 24, 2005 When you say dead do you mean no voltage. Try this link. http://www.cableforum.co.uk/?
