arfur mo Posted March 22, 2006 Posted March 22, 2006 That post gets an award.....First post by Arfur Mo that fits on a normal screen, so can be read easily. Bit of friendly advice AM - keep it short and sweet. so what your saying is 'less is more' i agree - pity i can't convince the wife B) but thanks for reading my 'tombs'. soz they get a bit long but it was a serious subject - to me at least regs arfur_mo If you think education is difficult, try being stupid!!!!
Guest Posted March 24, 2006 Posted March 24, 2006 use C curve to prevent lamps blowing the B curve MCB's After calculating that a type C MCB will still provide adequate protection in line with the original design spec.
Paul Giles Posted March 25, 2006 Posted March 25, 2006 Oh of course! PG Security Systems Somerset SSAIB Certificate of Merit Installers. www.pgsecurity.co.uk
Guest Guest Posted April 8, 2006 Posted April 8, 2006 Shouldn't the supply to the spur be in 2.5mm as it's rated at 13Amps?Obviously lighting ccts ain't usually wired in 2.5mm Regards Bellman Are you joking!! all that is needed for an alarm maximum is 3amps
bellman Posted April 8, 2006 Posted April 8, 2006 Are you joking!! all that is needed for an alarm maximum is 3amps I know this, I was refering to the spur, not the alarm Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
