Guest canadiak24 Posted June 1, 2005 Share Posted June 1, 2005 Hello all! does anyone know of a supplier who sells 'armed lamps/LED's'? I can't seem to track anyone down to supply with one and just wondered if anyone had a suggestion? Link to comment Share on other sites More sharing options...
Guest Posted June 1, 2005 Share Posted June 1, 2005 Have you thought about making your own, could be done fairly cheaply and source the materials from Maplins or the like?? - yet still look spot on. Link to comment Share on other sites More sharing options...
Guest canadiak24 Posted June 1, 2005 Share Posted June 1, 2005 Its a good point, why don't i make it myself?! I'm too lazy for starters! I don't usually get asked for such items it's been one of those weeks for unusual requests from custoners! Link to comment Share on other sites More sharing options...
Guest Posted June 1, 2005 Share Posted June 1, 2005 I know there are "detector activated" led plates for fire alarm systems, but there arnt so many LED plates specificly for intruder. The ones I have seen have been tailor made for a specific purpose Im affraid Link to comment Share on other sites More sharing options...
Guest Posted June 1, 2005 Share Posted June 1, 2005 tell the client that it does not meet the requirment of a british standard and to keep their daft ideas to their selfs(nicely) Link to comment Share on other sites More sharing options...
Guest canadiak24 Posted June 1, 2005 Share Posted June 1, 2005 well that saves me a job then! i don't know why they can't just remember when the friggin thing is armed and when it isn't...she'll find out when she steps into her lounge at 5am and a full alarm occurs that pretty much would tell her whether the system is armed or not!! Link to comment Share on other sites More sharing options...
Guest Posted June 1, 2005 Share Posted June 1, 2005 tell the client that it does not meet the requirment of a british standard and to keep their daft ideas to their selfs(nicely) 55509[/snapback] That was my first thought, although I suppose it would comply depending where you put it. Have a look at access control equipment, there's usually a few different types of plates with LED's in. Personally, I'd make one with a blank plate, a hole, an LED and a holder. Link to comment Share on other sites More sharing options...
breff Posted June 1, 2005 Share Posted June 1, 2005 tell the client that it does not meet the requirment of a british standard and to keep their daft ideas to their selfs(nicely) 55509[/snapback] You are allowed to indicate that the system is unset, so the led is on when unset and off when set. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
ian.cant Posted June 1, 2005 Share Posted June 1, 2005 As i recall you can indicate both, its just a matter of where you see the indication and clearly you should'nt be be able to tell from outside the premises. You could use a fire alarm indicator that you would use when a detector is fitted in a void. Link to comment Share on other sites More sharing options...
Guest Posted June 1, 2005 Share Posted June 1, 2005 As i recall you can indicate both, its just a matter of where you see the indication and clearly you should'nt be be able to tell from outside the premises. 55515[/snapback] That's what I thought. By the sounds of it the client in question wants indication internally for when it's set at night so an indicator on the landing\stairs would comply in this situation. Of course, I could have assumed the application incorrectly for this instance. Link to comment Share on other sites More sharing options...
