breff Posted June 3, 2005 Posted June 3, 2005 blank The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Guest Posted June 3, 2005 Posted June 3, 2005 releases ok then when renewing it comes up unable to connect to dhcp server, timed out 55808[/snapback] You need t either enable a DHCP server, either in a router or modem on the network with the DHCP server function within or set the IP address manually to a spare IP address in the range of your existing machines. To do this, right click on My Network Places and select properties, right click on the wired network connection and select properties then click TCP\IP Protocol and select the properties button. Set the IP address, the subnet mask of 255.255.255.0 and the default gateway with that of your router or whatever the machine access through. Set the DNS addresses to the same as the default gateway. Click OK etc... and it should all work.
Guest Posted June 3, 2005 Posted June 3, 2005 Set the DNS addresses 55815[/snapback] You leave my addresses alone ya big bully!
Security Technician Posted June 3, 2005 Author Posted June 3, 2005 You need t either enable a DHCP server, either in a router or modem on the network with the DHCP server function within or set the IP address manually to a spare IP address in the range of your existing machines. To do this, right click on My Network Places and select properties, right click on the wired network connection and select properties then click TCP\IP Protocol and select the properties button. Set the IP address, the subnet mask of 255.255.255.0 and the default gateway with that of your router or whatever the machine access through. Set the DNS addresses to the same as the default gateway. Click OK etc... and it should all work. 55815[/snapback] what do i need to set ip address to? and which machine should i be doing this on
breff Posted June 3, 2005 Posted June 3, 2005 whats the ip adress of the machine you are using now, if its 192.168.1.x, set the address on your laptop to 192.168.1.y if you know what i mean The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Security Technician Posted June 3, 2005 Author Posted June 3, 2005 i have set up ip address and subnet mask but it still does not want to play, it says connected but wont connect to net or view shared docs
Guest Posted June 3, 2005 Posted June 3, 2005 Go to the machine you are connecting the other end of this network cable to. Go to Start -> Run, type cmd and press enter. Type ipconfig and look at the IP address that comes up, (probably be 192.168.?.?). Set the IP address of your new machine to match the first 3 digits, but change the third to a different number, probably just +1 of what the address of the other machine in will do.
Guest Posted June 3, 2005 Posted June 3, 2005 Youve tried the obvious set up a home or office network wizzard and put the set up discs in the other pcs?
Guest Posted June 3, 2005 Posted June 3, 2005 How are you connecting to the internet, ICS or via a router? I assume this all worked before you re-installed?
Security Technician Posted June 3, 2005 Author Posted June 3, 2005 connect via cable into back of desktop, desktop connected to ntl broadband modem, tried wizzard etc, all worked last night prior to reload etc thing that puzzles me is my ip address is no where near what you are saying 80.6.23.222
