scart to bnc
Guest PcFairs
A Red wire - Connects from pin 18 to pin 21 = Earth points
A black wire - Connects to pin 21 = Earth point
A Red wire - Connects from pin 2 to pin 6 = Audio In (left/right joined)
A Black wire - Connects to pin 8 = Video Status
A White wire - Connects to pin 20 = video in (unscrambled)
BNC goes to 20 & 18 (20 being the BNC centre)
Audio connects to 2 & 6 (L & R) Cable shield to 18 or 21
  • 7 months later...
I have a Micromark wired CCTV camera but would like to transmit the pic/sound wirelessly using a Digisender I have. The Digisender transmitter would obviously normally take its input from the output SCART socket on a satellite/VCR/DVD.
Do you know if it is possible to use a Micromark CCTV SCART connector as a direct input into a Digisender transmitter (via a SCART female-female convertor for instance) instead of having to plug it into a VCR SCART input and then plugging the transmitter into the VCR output SCART?
Option 1 - obviously works
CCTV camera SCART ----->[VCR SCART IN][VCR SCART OUT]-----> Digisender transmitter
Preferred option 2 - if it is possible
CCTV camera SCART ------>[Fem. SCART to Fem. SCART connector]-----> Digisender transmitter
I have seen Female-Female SCART connectors available for a few quid with all the necessary pins crossed. Would this do anything differently than the VCR is doing between the 2 built-in female SCART sockets?
Alternatively, would it be possible to remove the CCTV SCART male connector and wire on a female socket with the above pins changed to 'audio out' and 'video out' pins (+any others needed)? If so, what pins would I need to connect?
If you can please advise on this I would be grateful!
Thanks a lot
Paul.
The female to female scart connector should work fine so long as it's a fully wired scart and not a cheapo one with only certain connections made.
  • 1 month later...
21 video ground 20 signal i think, not shure need to be looking at the plug its the two from the end.
:cry: It's pins 17 & 20. 20 screen, 17 composite video in :hmm:
I went up into the attic...I found a Stradavarius & a Picasso. Unfortunately.....
Stradavarius couldn't paint, and Picasso made a shocking fiddle.
My Facebook page...http://www.facebook.com/home.php#/profile.php?id=1279556853&ref=name
