Guest Coop Posted June 8, 2005 Posted June 8, 2005 Ever thought of including one on the site? - thinking of phrases like "pulse count", "double knock", "piece of sh*t"
ian.cant Posted June 8, 2005 Posted June 8, 2005 Ever thought of including one on the site? - thinking of phrases like "pulse count", "double knock", "piece of sh*t" 56372[/snapback] Not a bad idea so why dont you get typing?
Service Engineer Posted June 8, 2005 Posted June 8, 2005 Ever thought of including one on the site? - thinking of phrases like "pulse count", "double knock", "piece of sh*t" Agreed, anyone wanting to do a detailed glossary of alarm terminology please feel free to do so, I will feature it on the website with all due recognition if it's any good..! ........................................................ Dave Partridge (Romec Service Engineer)
Brian c Posted June 8, 2005 Posted June 8, 2005 would this be something for trade or public? I can't see why public would need to know? If you don't know......ask.
jb-eye Posted June 8, 2005 Posted June 8, 2005 You can have these for a start! ACFO Association of Chief Fire Officers ACPO Association of Chief Police Officers ARC Alarm Receiving Centre. A Secure location where signals are monitored 24hours a day. Area Segmented section of a security system BAFE British Approval for Fire Equipment BG Break-Glass BNC One of the most popular of the coaxial connectors, the BNC was developed in the late 1940s. The name BNC sands for Bayonet Neill Concelman. Bayonet describes the coupling mechanism, while Neill and Concelman were the inventors of the N and C connectors. The BNC is essentially a miniature version of the C connector which is a bayonet version of the N connector. BNC connectors are available in both 50 and 75 ohm versions, both versions will mate together. The 50 ohm designs operate up to a frequency of 4GHz. BNC connectors are used in many applications, some of which are flexible networks, instrumentation and computer peripheral interconnections. BS British Standard(s) BS4737 Standards for design, installation and maintenance of intruder alarm systems BS5750 Internationally recognised quality standard. BS5839 Standards for design, installation and maintenance of fire alarm systems. BS5979 Standards for construction and working of an ARC. BS6799 Standards for wireless intruder alarm systems. BSI British Standards Institute BSIA British Security Industry Association. BT British Telecom C&E Cause and Effect CCTV Closed Circuit Television Corrective Maintenance A call out, or engineer attendance to correct a fault. CPU Central Processing Unit (Computer) Digi-Com Digital Communicator Door Contact A normally magnetic switch, which detects if a door, is closed or open. Dual Tech (DTEC) Dual Technology - where a single device operates on two different typs of technology. Must common use is where a PIR and a Microwave detector is combined into one movement detector. Dummy Sounder An external sounder that provides a visual deterrent, but doesn't make any noise. Duress Code A number chosen by the user that, if used to unset the alarm will act as normal but will also send a personal attack (code 2) signal to the ARC. DP Distribution Point/Panel (Telecommunications) DP Double Pole (Relay) EAS Electronic Article protection System. E/E Entry/Exit EN European Norm EN501-31 Standards for design, installation and maintenance of intruder alarm systems Engineer Reset Where a system can not be reset by the user without assistance from the maintaining company. EOL End Of Line F/D Fire Door F/E Final Exit FSL Fully Supervised Loop. GPRS General Packet Radio Service GPS Global Positioning System GSM Global System for Mobile communications I.O Customers!
jb-eye Posted June 8, 2005 Posted June 8, 2005 Im finding fault already, anyone else spot them? Jef Customers!
Service Engineer Posted June 8, 2005 Posted June 8, 2005 Well if its on the main site it's public.. and just thinking of a few terms such as Double-knock & pulse count I can't really see the problem with that, and let's be honest most engineers wont need to referance it anyway..? But it may help out the public, and give them a better understanding of some alarm features they aren't aware of, and stop those questions being asked in the forums. ........................................................ Dave Partridge (Romec Service Engineer)
Brian c Posted June 8, 2005 Posted June 8, 2005 Yeah I suppose I can see most of Jef's list could be of benefit to public. If you don't know......ask.
Guest Posted June 8, 2005 Posted June 8, 2005 PIR = Passive Infra-Red Receiver. Sorry for being pedantic - but if your doing meanings, then you might as well give the correct meaning.
