cannot reset tamper??
Guest miger
Guest miger
>>does it have a groove running along the width of the panel
and screws at either end of the groove?>>
No Bellman,it's plain and slightly angled.
i've now put a new battery in and it's still the same-----------tamper light will not reset (and panel alarm doesn't sound when cover removed)
Beginning to think the boards kaput!
:dontgetit:
Guest Peter James
Possibly you have a tamper fault????(Theres a clue in which light is lit) check the global tamper circuit with a multimeter, if its not that then it is likely to be the sas (bell)tamper circuit.
Pete
Guest miger
it's not showing any fault lights from the zone PIR's or contacts to help, just the 'tamper' light ---when i try to do a set , all the zones are normal but the 'fault' light shows.
not sure how to check the global tamper circuit or the bell circuit!
Might be time to phone a company local to you to sort it out for you then mate :)
Guest miger
Yes---thanks again for all the advice, Much appreciated ;)
  • 2 weeks later...
Guest miger
Hi Guys1
Update on this is i gave up on the panel box & bought an Optima Compact G3 panel box
-------------trouble now is, i've fitted it but none of the PIRS are lighting-------any ideas?
the PIRS appear to be wired correctly------i'm not having much success with this !!
Probably because you are not an alarm engineer.
As stated in TWO posts above give a local company a call to help you out.
They may be able to certificate it for you too.
Paul
PG Security Systems
Somerset
SSAIB Certificate of Merit Installers.
www.pgsecurity.co.uk
57767[/snapback]
He's right, you think these panels aren't intelligent but they are, they can tell when your not a real engineer and refuse to work. This is proven even more so when a 'mate from down the pub' tries to fix things which usually results in your needing another control panel. :unsure:
Either that or you've most likely blown the fuse which controls the 12volt output to the pir's etc, or possibly wired them in backwards (12volt is now negative and vice versa) check for 12 volt's across the power terminals on your pir's.
Always replace fuses with ones of identical size and rating and if unsure ask a professional to do the job.
Guest miger
LOL!
