Guest Alan Posted June 14, 2005 Share Posted June 14, 2005 Hello everyone, I am half way through an installation consisting of the following: Dedicated 8 channel DVR 4 day/night domes. Having just powered up 2 of the domes they came on ok but are showing just mono images, however there is some colour on the screen, mainly in lines. Having not come across this before I would appreciate any help. I have adjusted everything on the dvr with no success. Link to comment Share on other sites More sharing options...
Guest Peter James Posted June 14, 2005 Share Posted June 14, 2005 The photocell in the dome may be covered so the cameras think its dark and have switched to mono perhaps? Link to comment Share on other sites More sharing options...
Nova-Security Posted June 14, 2005 Share Posted June 14, 2005 are the two domes you are having problems with powered from the same low voltage power supply ? if so is the PSU big enough to cope, check the current draw for the cameras and make sure that the PSU is big enough.. Best on seperate PSU, but if you have a seperate PSU for each at the moment then see Pete's post. DVR is setup for colour cameras ? (i had to ask the simple question) www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
Guest Alan Posted June 14, 2005 Share Posted June 14, 2005 The PSU is a Gardtec 3 amp PSU so no probs there, the photocell idea is very possible thanks. Any further ideas would help as it means I will have many optoions to try when I start again tomorrow. Thanks for the feedback. Link to comment Share on other sites More sharing options...
JB_ Posted June 14, 2005 Share Posted June 14, 2005 *looks around the room sheepish* Have you got a colour monitor on it? *runs away* Sorry I once spent a while trying to get some colour cameras to work on what I was assured was a 'colour' monitor. Except it wasn't. Link to comment Share on other sites More sharing options...
Guest Alan Posted June 14, 2005 Share Posted June 14, 2005 Yes the thought had crossed my mind too(so I checked) but its always the silly things that take up the time and effort isn't it. Link to comment Share on other sites More sharing options...
Nova-Security Posted June 14, 2005 Share Posted June 14, 2005 The PSU is a Gardtec 3 amp PSU so no probs there, the photocell idea is very possible thanks. Any further ideas would help as it means I will have many optoions to try when I start again tomorrow. Thanks for the feedback. 57067[/snapback] Check the voltage coming out, and try one camera only i bet you get a picture, not the best PSU to use, we would always use single PSU for each camera cuts down on problems of noise and horizontal ghosting lines. Try just one and see what you get. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name. Link to comment Share on other sites More sharing options...
ian.cant Posted June 14, 2005 Share Posted June 14, 2005 I would put my money on the probability you powered up the DVR then added the camera's. Reboot the PC and send the case of J Smiths too............ Link to comment Share on other sites More sharing options...
C.S TEK. Posted June 14, 2005 Share Posted June 14, 2005 Have you got the setting on the dvr set up for NSTC and not PAL. Some DVR's will automatically switch to NSTC if you power up with out any cameras on Chris ISC Systems Ltd Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006 Link to comment Share on other sites More sharing options...
C.S TEK. Posted June 14, 2005 Share Posted June 14, 2005 Great minds aye ian cant Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006 Link to comment Share on other sites More sharing options...
