Guest VOLCANO Posted June 15, 2005 Posted June 15, 2005 Hello I am trying to work out the connections to wire my alarm into a bell box. The bell box has the following points where i can wire into: T E A D + B my panel has the following points: negative bell trigger strobe switched negative tamper tamper ground oV -ve supply +12v +ve supply any advice gratefully received. volcano :!:
Guest Peter James Posted June 15, 2005 Posted June 15, 2005 Hi Volcano Welcome to the forum What make is the bell bo and the cpu? Pete
Guest VOLCANO Posted June 16, 2005 Posted June 16, 2005 hi, i don't know the make of the bell box. I can't see the name anywhere. The panel is Visonic PowerMax. Hope this helps.
FASTCAR Posted June 16, 2005 Posted June 16, 2005 Connections look similar to a Sonade . worth a try. T = tamper return (to control panel) A = neg supply D = pos supply B = neg trigger for siren E = link to neg ( A ) there should be separate strobe connections.
Guest ttsfiresecurity Posted July 19, 2005 Posted July 19, 2005 "The panel is Visonic PowerMax" Be careful with the powermax panel as it does not have maintained 12v supply and will cause alarms every time their is a powercut. The powermax+ Plus panel is ok as it has maintained 12v output. Tony
