Guest ALSEC Posted June 24, 2005 Posted June 24, 2005 Wire 0.75 flex into a connector block with the auxillarys twisted together into that and simply take one leg into the panel connections. 57336[/snapback] Nice Paul, I like seeing this done it always looks a more solid way of doing it to me.
newbec Posted June 25, 2005 Posted June 25, 2005 I wouldn't have thought you would have too much trouble getting 5 wires into Aux+ and Aux - - are you putting them all directly into the 12V source - (don't wire them in series as you have for the tamper circuit). 57314[/snapback] Many thanks for everyones repliesSorry - surely the power has to be connected in parallel for the powered detectors or have I misunderstood what you've written? 58162[/snapback] I think you may have misunderstod, you do indeed need to connect all 12V power conections to devices in parallel. 58166[/snapback] Yea! Wot he said (coop) only he spelt it correctly! . Trade Full Member
