Guest daborg Posted June 25, 2005 Posted June 25, 2005 I'm about to completely uninstall existing setup of ts690+lcd+ext.sounder -the 690 installation manual does not mention any unistall procedure. I was looking for some tips...do i just put the eng pwd and start disconnecting everything? shouldn't be a probelm but wanted to do it the 'right' way if possible. Thanks in advance for any help.
Guest Posted June 25, 2005 Posted June 25, 2005 Im sorry my friend but that information cant be given out on a public forum.
Guest daborg Posted June 25, 2005 Posted June 25, 2005 OK I can see your point. I just wanted it removed and kept for future use. Who should I get in touch then? The place where I purchased it I take it?
norman Posted June 25, 2005 Posted June 25, 2005 Who should I get in touch then?The place where I purchased it I take it? 58388[/snapback] Yes that would be a good starting point but any local company would oblige Im sure. Nothing is foolproof to a sufficiently talented fool.
Guest daborg Posted June 25, 2005 Posted June 25, 2005 thank you. normall the charge for this may be around £***?
Guest Posted June 25, 2005 Posted June 25, 2005 Maybe someone near to you on here might be good enough to PM you a price to do the task you require.
morph Posted June 25, 2005 Posted June 25, 2005 In West London, you would be able to get it deinstalled for about £75.
Guest daborg Posted June 25, 2005 Posted June 25, 2005 sounds to much for what i'm willing to pay. can i just ask you if a 'Factory Reset' is what i really need and that would be enough. or, there is more to it than that? 'Factory Reset' sounds like its enough, am i correct?
