Uninstalling TS690
Guest daborg
No It wont be enough if your decommisioning a system. It needs to be done properly and in a certain sequence, if you dont know how to do it, you will have to call someone in sory.
If you dont do things correctly you will risk damaging the equipment, possibly even destroying it.
An alarm company would bill you as a minimum for two hours and depending on where you live in west london, there may also be parking costs. You should also be aware that the rules on alarms are about to change again in October, whereby your alarm may not be acceptable to your insurers if its reused.
You also have to remember that you are in addition to paying fory the alarm company to do the job, you are also paying for there technical knowledge.
