Guest davebruton Posted June 26, 2005 Share Posted June 26, 2005 Have GV 1000 card from ezcctv have tried it with 2 deferent setups Setup1 Intel LG 560 3.6 gig ASUS P5GD1 Intel 915G Express / Intel ICH6MHz Intel HD Audio - 7.1 channel surround DDR400 2GIG Radeon x600 pci express also tried fx6600pro Sata raid 2x400gig SETUP 2 Intel LG 560 3.6 gig ABIT AS8 Intel 865PE / Intel ICH5R 800 MHz Radeon 9600 256meg pro agp DDR400 2GIG Sata raid 2x400gig On both setups drivers and main program install with out eney problems ore conflicts BUT on start up main program will not inisalise and the program freezes this happens With both setups program will not start up pal setup BUT if program is installed as NTSC format it will work ok but as im in the UK It is not compatible with my cameras NOTE my old gv800 board will work OK Ezcctv have tested the board and ok have also replaced with a new one and bean very Helpful but do not have the answers they think it should work with both setups Thanks for eney help you can provid Dave Link to comment Share on other sites More sharing options...
securitycctv Posted June 27, 2005 Share Posted June 27, 2005 Were you supplied with Pc for this? If so it might be worth talking to PC supplier or an IT wiz on harware configuration of system. May be conflicts or something on that line in machine John Link to comment Share on other sites More sharing options...
Rich Posted June 27, 2005 Share Posted June 27, 2005 It sounds like the software is at fault, get them to send you the correct software for your operating system. Link to comment Share on other sites More sharing options...
