Another Question for you experts out there
Guest xinacoco
Guest xinacoco
The system used to be monitored. how do I revert it back and reprogramme the system so that it is customer reset only
thanks for your help
William
xinacoco@aol.com :fyi:
  • 3 weeks later...
Guest charlesmarks
Did you get a solution to this? I have the same question and no, I do not know the engineers code, but I know that it has not been changed as the salesman looked at the system and said his old engineers code still worked.
Thanks
Charles.
If you email with your contact details, I should be able to help both of you, as the company that I worked for in London installed severall hundred systems for //.National Installer.// in the West/Central London area.
Colin.
