Guest conovii Posted June 29, 2005 Posted June 29, 2005 Hi All. After a recent storm the strobe is flashing but i have no power to the control panel of my citadel xr2. It should show 2 lights, a power light and a day light but does not show any. I have power to the main panel. The previous owners left no instruction book. Can anyone please help?
Guest Posted June 29, 2005 Posted June 29, 2005 Sounds somewhat fried unfortunately. I take it there is no response from the keypad? An engineer would probably be the best option by the sounds of it. Whereabouts are you?
Guest conovii Posted June 29, 2005 Posted June 29, 2005 Hi Lurch. You are right, no response from key pad. I am in Telford, Shropshire.
Guest Posted June 29, 2005 Posted June 29, 2005 Only round the corner from me then. If it has been affected by the lightning it would be a good idea to get it serviced to make sure everything is still in working order.
Guest vinnys Posted September 19, 2005 Posted September 19, 2005 Hi Convoii, if you have the XR2, and after a lightening storm, open the main control panel up and check the glass fuse for the keypad (inside the control power unit). The fuse for the keypad is in the lefthand side of the control panel next to the wiring block for the keypad. If the fuse tests okay its possible that a section of the control panel has blown or the the keypad itself is fried.
advancedprotection Posted September 19, 2005 Posted September 19, 2005 I would strongly reccommend you get an alarm engineer around to service your panel as there is 240volts present inside the panel !!. also with little knowlage of alarm panels you could do more damage than good Martin Trade Member It's nice to be important but it's more important to be nice!! Martin Hanfo CCTV - Intruder Alarms - Access Control - Security Lighting - Locks Covering South Wales 07903 967045
Guest Posted September 19, 2005 Posted September 19, 2005 No need to reply to this thread any more, the fellow got it sorted cos he had a mate who once fitted a few of these and he 'reset it'.
Guest DaveGandT Posted December 20, 2005 Posted December 20, 2005 Hi All.After a recent storm the strobe is flashing but i have no power to the control panel of my citadel xr2. It should show 2 lights, a power light and a day light but does not show any. I have power to the main panel. The previous owners left no instruction book. Can anyone please help? Hi All I have a similar but different problem with my Citadel XR2. On Saturday we had a power cut for about 4 hours and the alarm sounded for a while then stopped. The strobe is still going. Hower the system ain't working! The backlights to the keypad are lit, but no other lights are indicating and the keypad does nothing. Also there is a red LED lit on the control unit - I'm not sure it's always been red or whether it was green before. I had the system installed 5 years ago but can't get hold of the engineer just now - think he may be on holiday. I only have limited documentation for the system and it doesn't help. Can anyone suggest whether I can reset the unit, whether it's fried, or anything else that might help? Thanks in anticipation of your help. David
morph Posted December 20, 2005 Posted December 20, 2005 Hi AllI have a similar but different problem with my Citadel XR2. On Saturday we had a power cut for about 4 hours and the alarm sounded for a while then stopped. The strobe is still going. Hower the system ain't working! The backlights to the keypad are lit, but no other lights are indicating and the keypad does nothing. Also there is a red LED lit on the control unit - I'm not sure it's always been red or whether it was green before. I had the system installed 5 years ago but can't get hold of the engineer just now - think he may be on holiday. I only have limited documentation for the system and it doesn't help. Can anyone suggest whether I can reset the unit, whether it's fried, or anything else that might help? Thanks in anticipation of your help. David Has it ever been serviced? or the battery changed?
