Looking for programming info for an LG GDK 70+
With the CO line thing it will alway pick the highest availiable line and if the slot assignment is such that the LCOB is acting as a higher line number it will show them. I would say programe all of the unused lines into a dead group. This should be done after the slot assignment.
  • Replies 63
  • Views 17.6k
  • Created
  • Last Reply
Right I am not sure where to start.  I am from the UK yes.
If it is saying united kingdom on the display this is a good thing.  But I would still say check that the dialing tone is normal for UK when you pickup the handset as this is normally the biggest givaway that it is set to the wrong code.
When first installing a system there are the things you have to do first to save confussion.  First is the country code then it is the slot assignment.  Make sure they are in the right order and that you only have the slot assigned that you are using.
This will make sure that all of the line and sta numbering are all OK.
It looks like you are running a provisional software version 5.  this is a good version and should have lots of features that you will be using with the WTIB.  You may even find that there is a WTIB section as part of the slot assignment.
Right now I will takle the other questions.
61504[/snapback]
I am online at the moment, but not with the system, so this is from memory.
Internal dialling tone sounds normal, but I haven't been able to connect to an outside line yet because the TJF is wrong. Pressing flex button 12 (says it is LOOP) siezes line 18 (etc). Pressing flex button 1 (says it is LINE 1) gives ACCESS INVALID (or similar) but there was no line connected.
When I have rewired the TJF to give access to all CO lines I will try again.
I presume I need to set up all the slots using admin function 02, what function would I use for country code?
I have written down all the admin setup prompts so we can be talking about the same thing
00 INITIALIZATION
01 FLEX NUMBERING (01-24)
02 FLEX SLOT ASSIGN
04 INTERNETWORKING SYSTEM PGM
06 EMERGENCY SVC CALL
08 SYSTEM ATTRIBUTE 4
09 ISDN COLP TABLE
10 STATION ATT 1
11 STATION ATT 2
12 STATION ATT 3
13 STATION ID ASSIGN
14 STATION COS
15 LINE GROUP ACCESS
16 ICM TENANCY GROUP
17 INTERNAL PAGE ZONE
18 CALL FWD PRESET
19 IDLE LINE SELECTION
20 SMDR ACCOUNT GROUP
21 STATION ATT 4
22 CTI STATION ATT
23 STATION ATT 5
24 STATION ATT 6
29 FLEX BUTTONS
30 CO LINE ATT 1
31 CO LINE ATT 2
32 CO LINE RING
33 CO FLASH TIMER
34 OPEN LOOP DETECT
35 CO/TIE LINE ASSIGN
36 DID LINE ASSIGN
37 CO LINE ATT 3
40 SYS ATT 1: SHLD PRIV PWRN
41 SYS ATT 2: BGM1 MOH1 BOX1
42 SYS ATT 3: EXTR RR CDIAL
43 SYSTEM TIMERS 1
44 SYSTEM TIMERS 2
45 ADMIN PASSWORD
46 MAIN ATTENDANT ASSIGN
47 STATION GROUPS
48 HUNT GROUP ATTRIBUTE
49 EXEC/SEC PAIRINGS
50 ALARM ATTRIBUTES
51 EXTERNAL CONTROL CONTACT
52 PABX ACCESS CODES
53 LONG DISTANCE CODE
54 AUTHOR CODE
55 DID DIGIT CONVERSION
56 DID/DISA DEST (TONE/ATD)
57 PULSE SPEED DIAL RATIO
58 MODEM ASSIGN
59 DATE & TIME
60 LCD DISPLAY MODE
61 Software version
62 SAVE PRT LD PIC DETL
63 SMDR COST PER UNIT
64 CANNED TOLL TABLES
65 TIE LINE ROUTING
66 GAIN (0-63): DKT EKT SLT
67 SYSTEM SPD ZONE PGM
68 ACNR TONE CADENCE (20MS)
69 SYS-TONE FREQUENCY
70 EXCEPTION TABLES
71 WORLD TIME ATTRIBUTE
72 DISPLAY WORLD TIME
73 VOICE MAIL DIALING TBL
74 DISPLAY COL NAME
75 RING FREQUENCY
76 DISTINCT RING FREQUENCY
77 DCO TX GAIN(0-63): DKT
78 DIGIT INSERT TBL
79 CUSTOM CALL ROUTING(0-9)
80 PRINT DATABASE
90 UK AC15 ATTRIBUTE
91 UK LCR ATTRIBUTE
92 ARS NETWORK ACCESS CODE
93 LCR NETWORK AUTHO CODE
94 DEALY DIALING TMR 01-15
95 MERCURY LOOK UP TABLE
96 ARS TABLES 3,4,5,6
97 ARS ROUTE ATTRIBUTE
98 ROUTE LIST TABLE
99 STATION ARS ATTRIBUTE
I am going to redo all the amphenol connections to make all the exchange lines available (and get rid of the waste of space in the extension wiring).
The wiring for the Digital extenssion are ment to be as every other as this is the way they are presented on the amphenol.
When it comes to the LCOB Wiring it will depend on the slot that the card is installed in to determine the wiring on the ampenol. This will need to be refered back to this diagram.
I have come to the conclusion that I have been given the wrong TJF for this system.
61516[/snapback]
Yes, I can see that digital and analogue cards are the same, every other pair is used and I can rewire accordingly.
61516[/snapback]
The CO wiring comes from an amphenol on the backplane, I have traced the wiring of this and can see that 12 pairs from the top two slots (5 & 6) appear in it, along with 3 pairs changeover (18 contacts) from the 3 powerfail relays.
Hopefully when I get the slot assignment right the line numbering will become (1-12). I expect the programming at the moment assumes 3 CO line cards, which is not possible with this cut down backplane.
The reason for the linekey 12 giving you line 18 is that it in default is programmed as a loop key this is better known as the dialing 9 function. It will pick the lowest group highest line in that group. To change the group assignment use CO Attrib 1.
Trans 30 then the line range
0330
Flex 1
dial 49
Hold
This will put all of the lines from 03 to 30 into a dead group.
61518[/snapback]
The cut down backplane was not a issue as it still used the same firmware. so as far as the programming is concerned it is a 186. It will show these slots as being availiable just remove the slots from the slot assignment as all the slots are assigned on a default powerup.
I am sorry if I have bombarded you with info but if there is something I have missed just let me know and I will try and help/
61521[/snapback]
Thanks. I'm not bombarded, the more info the better. I won't be disturbing you again until I return home tomorrow and repunch the TJF.
